-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   negative values for diffusion scalar (http://www.cfd-online.com/Forums/cd-adapco/54524-negative-values-diffusion-scalar.html)
cmv April 18, 2005 06:21
Hi
The situation is very simple; I have defined a passive scalar and define it to be solved by diffusion. If you take a slab of cells and inject this passive scalar at one end and extract it at the opposite side, normally you would expect to have a zero value somewhere near the middle of the slab.
The problem is that I have not been able to get this 0 point at the middle of the slab but almost near the extraction region.
I have plot the value by monitoring the scalar at the injection & extraction regions but I get a correct value only on the injection region and I usually get a slightly negative value on the extraction region. I would expect these to be the same size but with opposite signs.
Do you know why it is not the same magnitude?
