Home > Forums > CD-adapco
Regarding Turbulence-Reynolds Number
Old   April 28, 2005, 01:05
Default Regarding Turbulence-Reynolds Number
LeelaPrasd
when dealing with Engine Intake flows Why genenally people will prefer"K-E/High Re.number"option why not "K-E/Low Re.no"option. What will happen if we use "K-E/Low Re.no"option.
Kindly explain me
Old   April 29, 2005, 23:22
Default Re: Regarding Turbulence-Reynolds Number
som
for "K-E/Low Re no. u hav 2 use two layer model tht is not compatible to er case. Not in engine intake flows but most of cases use K-E/High Re.number.
Old   May 1, 2005, 11:26
yacine
In my opinion is more to do with the grid !!! if you are using hi-Rey number then the fist cell at the wall should be placed at y+ around 30 to 100 if you use low-Re model then y+ need to be a unity at the wall Hi-Rey model use a wall function while Low-Rey doesn't. two-layer models are simplified version but still you need to refine the grid with these ones too for more info check the manual.
Old   May 2, 2005, 00:01
azmir
Low-Re models will invoke more detail and accurate calculations near the wall at the expense of pre & processing time. However, the details obtained may not be relevant to engine intake case where pressure drag/loss is of interest and not skin friction. Maybe that's why more people use hi-Re for this flow case.
Thread Tools
Trackbacks are On
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
Reynolds number sisir FLUENT 1 August 18, 2008 12:43
Cell reynolds number and turbulence Gavrilo Bozovic Main CFD Forum 0 February 21, 2008 05:04
Turbulence Model for low Reynolds Number Muhammad Shakaib Main CFD Forum 2 July 3, 2006 15:42
turbulence model for low Reynolds Number Muhammad Shakaib FLUENT 0 July 3, 2006 08:03
