flexlm hostid (license problem)
Old   June 7, 2005, 09:40
Default flexlm hostid (license problem)
cirilo
Hi
I changed computer and asked for a new license. This computer for some reason has defined a eth0 : 00000000000 and eth1 : with its physical address. When I try to comprise the license server it tells me that the hostid on the machine and the one on the license file do not match. The problem is that it tries to read eth0 instead of eth1.
I know this has not much to do with starcd but perhaps someone here have had a similar problem.
Appreciate any help
Kind regards
C
Old   June 8, 2005, 07:10
Default Re: flexlm hostid (license problem)
Piet
shutdown eth0
Old   June 8, 2005, 19:17
Jihwan
I had this problem in a year ago. Using your unix manager program or unix command, you need to deactivate eth0 first and then reboot again. The OS will recognize eth1 as the primary device. Good luck
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
STAR-CCM+ license problem Ankur Srivastava Siemens 1 October 10, 2008 21:54
Use of FlexLM license via VPN Tim Main CFD Forum 3 April 28, 2008 15:27
FLOVENT LICENSE- Problem reloading Cristina Main CFD Forum 0 March 22, 2007 19:16
Problem in License Server kumar FLUENT 4 November 24, 2002 00:49
