Convergence problems
Old   June 29, 2005, 03:07
Default Convergence problems
Simone
I'm currently experiencing some problems in reaching the convergence in STAR-CD calculations. I have already tryed to reduce the mesh size and/or to change the boundary conditions to help reducing the residual values, but after some iterations, they always start obscillating between 10^-1 and 10^-2.
Is there any trick I can use to solve this problem?
Thanks a lot.
Simone
Old   June 29, 2005, 06:50
Default Re: Convergence problems
4xF
Is your problem really steady-state?
Old   June 29, 2005, 07:27
Simone
Yes! It is a really steady-state problem!
Can you help me, please?
Simone
Old   June 29, 2005, 09:10
4xF
To me it looks like your problem may be a REAL transient and you try to enforce a steady-state solution. That may be the reason why you cannot get a converged solution, because the flow physics may be wrong.
Old   June 29, 2005, 10:03
Simone
It's possible! How can I have a transient solution?
Old   June 29, 2005, 10:48
4xF
Change the analysis type from steady-state to transient?
convergence problems using SBF=1 Fonzie CFX 1 March 23, 2007 08:46
Convergence Problems Carlos FLUENT 0 March 12, 2007 02:44
Problems with Convergence Andres Bernal Ortiz CFX 2 January 16, 2007 07:58
Problems in convergence Simon Siemens 3 February 14, 2005 05:36
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
