Question about moving meshes at star-cd 3.22
Old   June 22, 2005, 03:22
Default Question about moving meshes at star-cd 3.22
Tiny
Hello I am a new hand; I have a question at moving meshes.
Can anyone help me? Please.
7-1 describes: The sliding mesh method utilises two basic moving mesh operations:
1. Change of mesh geometry 2. Change of cell connectivity
Now, if I want use method one, Where I should go to write cgrid.cgrd ?or how to write?
I don¡¦t understand what it is describing?
Thank you and have a good time.
Old   June 22, 2005, 08:49
Default Re: Question about moving meshes at star-cd 3.22
Guillaume
You have to use both method. Star needs method one to define the movement of the vertices (this is the role of cgrid.cgrd which is written in the working directory). Method two is applied once the move has been done to redefine how the cells are connected to each other given their new location.
Old   June 24, 2005, 18:01
saang
I am the one using cgrid.cgrd. The key idea is to prescribe the moving mesh at every time step. I use external source file to read cgrid.cgrd. Then, I prescribe the mesh in cgrid.cgrd.
- Write source file and import to Prostar by using command "ifile". This is the sample of source file
mvgr on, event
memory maxeve 1001
evfi init
*set evno 1 1
*set etim 0 .000001
*defi
evst evno time etim
egrid read cgrid.cgrd
evsa evno
*end
*loop 1 1000 1
- Next, define the moving vertices in cgrid.cgrd. You just prescribe the path of the vertices (using vertex number) u want to move. I think u can find a sample of cgrid.cgrd file in manual
Hope it help u some and Good luck
Saang
Old   June 29, 2005, 11:07
Tiny
Dear all I try it Thanks
VOF and moving meshes Dave FLUENT 0 May 7, 2007 01:54
Moving meshes charlotte Main CFD Forum 5 September 19, 2006 07:52
Moving meshes Kraev Stanislaw Main CFD Forum 2 April 11, 2003 13:09
Moving meshes, is that possible Stanislav Kraev Siemens 0 April 8, 2003 11:23
Is it necessary to apply moving meshes? raymond Siemens 9 October 1, 2001 17:11
