no .pst file!!! need help...
Old   July 5, 2005, 13:51
Default no .pst file!!! need help...
Kevin Till
I am running my analysis and it is reaching convergence just fine. However, it is not writing any output files? e.g. no .pst file. How is this happening?
Old   July 5, 2005, 14:12
Default Re: no .pst file!!! need help...
Sheila
Check the following,
Analysis Controls > Output Controls > Analysis output
The button for "Write Solution File (Restart File)" should be ON for pst files to be written.
Old   July 13, 2005, 01:31
bv
If u r running on dual processors, it will write two seperate .pst files in in files CASENAME_001 and CASENAME_002. Some times it will not wright combined .pst in the working directory.
if u have seperate .psts in _001 and _002 floders, u can merge them to get single .pst.
Check.. BV
Old   July 13, 2005, 11:02
Kevin Till
Thanks for the help guys. I was able to fix the problem by copying all of my files to another directory and trying again. Just another quirk I of StarCD I guess. Thanks though.
- Kevin
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 09:48
[OpenFOAM] ParaView exiting while trying to save image file or movie file 21kalee ParaView 3 January 23, 2008 16:01
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 13:48
Covert gambit file to polyflow file John FLUENT 5 August 6, 2004 08:31
Converting a surface file to a volume file Amir FLUENT 2 December 30, 2002 04:53
