Home > Forums > CD-adapco
Highlighting the Adiabatic tab
Old   July 5, 2005, 18:36
Default Highlighting the Adiabatic tab
Lalith
Hey folks,
I know that the walls in STAR CD are adiabatic by nature. How do I put a constraint on one of them to have a constant heat source? In short how can I make the adiabatic tab active?
Thanks in advance.
Lalith
Old   July 5, 2005, 22:02
Default Re: Highlighting the Adiabatic tab
Sheila
If you have the Conjugate heat transfer set to ON in Thermal option, you should be able to set the wall condition to constant heat flux or fixed temperature on the Define Boundary Region tab. Change the Wall Heat to required state.
Sheila
Old   July 6, 2005, 23:32
som
hi Sheila, I think if u dont switch on congugate heat transfer even then u wld be able to define heat flux or fixed temperature on wall.
Old   July 7, 2005, 05:23
Volker
Som is right. You just have to activate the temperature calculation if you want to define a wall temperature or heat flux.
Thread Tools
Trackbacks are On
adiabatic wall MMACRB FLUENT 0 January 28, 2007 15:16
adiabatic combustion pp FLUENT 2 March 8, 2005 03:34
Does anyone know the non-adiabatic PDF generation? Jimmyfox FLUENT 0 January 4, 2004 13:49
Adiabatic condition!!! Srinivas Main CFD Forum 1 April 4, 2002 11:41
