July 5, 2005, 13:51 |
no .pst file!!! need help...
I am running my analysis and it is reaching convergence just fine. However, it is not writing any output files? e.g. no .pst file. How is this happening?
July 5, 2005, 14:12 |
Re: no .pst file!!! need help...
Check the following,
Analysis Controls > Output Controls > Analysis output The button for "Write Solution File (Restart File)" should be ON for pst files to be written. |
July 13, 2005, 01:31 |
If u r running on dual processors, it will write two seperate .pst files in in files CASENAME_001 and CASENAME_002. Some times it will not wright combined .pst in the working directory.
if u have seperate .psts in _001 and _002 floders, u can merge them to get single .pst. Check.. BV |
July 13, 2005, 11:02 |
Thanks for the help guys. I was able to fix the problem by copying all of my files to another directory and trying again. Just another quirk I of StarCD I guess. Thanks though.
- Kevin |
PLOT3D ASCII solution file to MATLAB data file | Sandeep Rana | Main CFD Forum | 4 | June 11, 2010 09:48 |
[OpenFOAM] ParaView exiting while trying to save image file or movie file | 21kalee | ParaView | 3 | January 23, 2008 16:01 |
Changing gambit file without change of case file?? | Asghari | FLUENT | 2 | August 28, 2006 13:48 |
Covert gambit file to polyflow file | John | FLUENT | 5 | August 6, 2004 08:31 |
Converting a surface file to a volume file | Amir | FLUENT | 2 | December 30, 2002 04:53 |
