August 9, 2005, 00:48 |
Recommended values on turbulence B.C.
Hi there,
I am not good at turbulence. But, as you know, it is very important to consider turbulence for the flow in complicated geometries. What I want to know is that whether there are good recommendations for the turbulence boundary conditions. Of course, the turbulence B.C. should depend on flow pass and environments. I hope to get any literature concerning recommended turbulence boundary conditions for various flow conditions and geometry. Thanks in advance and good luck everybody Jihwan |
August 10, 2005, 03:53 |
Re: Recommended values on turbulence B.C.
Hi, Turbulence Boundary condition in the sense u need to maintain a suitable Y+ values around the wall region and which inturn depend on ur tubulence models which u r going to use. For each TModels appropriate closure coefficients u need to use usually software will take care by using its default values.
U need to check for gridsenstivity. regards' Alex |
August 10, 2005, 07:45 |
Hi
If you are considering inlet boundaries then you could try setting turbulence intensity to say 2%, running the model then double it and run the model again and so on until there isn't any appreciable difference in the turbulent flow field. For internal flows length scale can be set to 10% of the hydraulic diameter of the duct. Y+ is also very important, but if you choose hybrid wall functions then it becomes less of an issue. allan |
turbulence values | nando | FLUENT | 0 | December 12, 2005 03:45 |
values for turbulence models | Ben | Siemens | 8 | July 12, 2004 13:42 |
Help - Wind Turbulence Values | Erich | Main CFD Forum | 0 | November 11, 2003 18:32 |
Turbulence boundary values | lego | CFX | 9 | October 25, 2002 11:55 |
Turbulence boundary values | lego | Main CFD Forum | 0 | October 24, 2002 13:47 |
