July 12, 2005, 14:57 |
Trouble with meshing in Pro-am
Hi all
The problem i'm faced with is as follows im creating the mesh of the geometry using the Mesh wizard, in step 3 (Generation of subsurface) u specify the cell type that determine the inlet and outlet of the flow (it seem to go well). when i get to the final stage of Generating the assembly of the mesh, (outer and inner layer) the outlet and inlet of the mesh are meshed as if they were wall, and they appear to have 'Zero Face area' and 'Negative Volume Failure'. I have tried several times remeshing the geometry with different cell values and subsurface thickness, but i still have the same problem. What can i do to avoid this? |
July 13, 2005, 04:41 |
Re: Trouble with meshing in Pro-am
I don't use the wizard, but it sounds to me that you need to specify your inlet and outlet when you create the extrusion layer. Proam 3.24 (without the wizard) recognizes these cells automatically. I think in the older versions you have to delete the appropriate cells in the 'surface for extrusion'.
Hope that helps, Volker |
Display Modes | |
VSAERO trouble | Bart Horsten | Main CFD Forum | 1 | September 12, 2013 17:10 |
UDS trouble | Jenny | FLUENT | 0 | July 7, 2008 04:27 |
UDS trouble | Jenny | FLUENT | 0 | July 6, 2008 05:09 |
Mixed stairstep + submap meshing trouble | Paweł | FLUENT | 0 | August 4, 2006 07:48 |
udf trouble | Eric | FLUENT | 1 | July 6, 2004 15:49 |
