how to import files of "CATIA"?
Old   July 13, 2005, 05:08
Default how to import files of "CATIA"?
ATao
hi,i save catia file to .stl ,but when i import it with prostar or pro-am,software tell me "no file be found". why does it happen?can you tell me?
Old   July 13, 2005, 05:22
Default Re: how to import files of "CATIA"?
KIO
hi
you can do surface mesh in CATIA and save it in *.dat fromat. while importing it in proam, use type NASTRAN and MATERIAL best regards
Old   July 13, 2005, 05:27
som
one more thing that u can do is save the surface as *.igs file and then import it in Pro-surf
Old   July 13, 2005, 06:12
KIO
you can follow the sequence
1. cad surface(*.igs) to prosurf 2. save as *.dbs (surface mesh)or in *.cel, *.vrt to proam
Old   July 14, 2005, 20:45
limingtiger
maybe your path to *.stl is not in english.
Old   July 24, 2005, 07:52
Hubert Janocha
Is the *.stl file greater than 2 GB? (For example a very big/complex fine resolved geometriy with maxsag of 0.001 (or about) and STL in ASCII).
If so try using the binary STL format in CATIA. That would reduce the file size dramatically.
"""Source Term in UDS""" Sebeci FLUENT 6 April 16, 2003 12:46
DIFFER IN "RESULT" AND "Q1" Baizhong Phoenics 1 December 9, 2001 09:41
"laminar" incomp. N-S eqs. for "turbulent" flows wowakai Main CFD Forum 4 November 27, 2001 05:48
what's the difference between "successive substitution" and "segregated" solutions?? wai Main CFD Forum 1 December 28, 1998 09:24
