Parallel processing in star3.24
Old   July 15, 2005, 06:37
Default Parallel processing in star3.24
Antony
Hello Everybody In our Institute we have starCD 3.24 solver with 16 processors (single host with 16 processor). I want to set up moving mesh case(Internal combustion Engine) with parallel computation i.e Parallel computation of single Host with 16 processors. Can anyone please help me .
Thanks in advance
Old   July 15, 2005, 13:04
Default Re: Parallel processing in star3.24
Kevin
I want to know too!
Old   July 15, 2005, 13:56
Richard
Have you tried just typing 'star 16'?
Old   July 15, 2005, 16:19
Ben
lol the problem they will have is with the decomposition of the mesh, if they decompose auto then metis will fling the ASI's far and wide and Star wont run. You will have to do a manual decomp by sets and makes sure that each attach boundary is on one processor.
Old   July 19, 2005, 00:45
Antony
Thanks a lot Ben,
I tried with manual decomposition. It worked fine,but at the time of starting the case it exited with the message:
PNP: Initialized [2005-07-19-10:11:28] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "cliff,10" resource (10 processes). PNP: Overload STAR master processor with external moving mesh code. PNP: Assigned "cliff,10" to STAR solver (10 processes). PNP: Assigned "cliff,1" to external moving mesh code (1 process). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Loading MPICH 1.2.4 ch_shmem (ANL/MSU MPI) dynamic shared object plug-ins. PNP: Loading STAR user coding dynamic shared object plug-in. PNP: Loading STAR user coding dynamic shared object plug-in. PNP: Decomposing STAR mesh using "manual" method for 10 domains. PNP: Analyzing Moving mesh events PNP: Copying STAR shared input file "engn.prob" to domains. PNP: Copying STAR shared input file "engn.drp" to domains. PNP: Copying External moving mesh code input file "mvmesh.sh". PNP: Copying External moving mesh code input file "param.prp". PNP: Copying External moving mesh code input file "engn.mdl". PNP: Copying External moving mesh code input file "engn.evn". PNP: Copying External moving mesh code input file "engn.cgrd". PNP: Copying External moving mesh code input file "engn1.cgrd". PNP: Starting TRACKER task on "cliff" for monitoring host and process failures. PNP: Spawning STAR processes on single node. 3 - MPI_RECV : Message truncated [3] Aborting program ! [3] Aborting program! STAR 3.22.000 [StarKin_003]: sunos64_5.8-ultra3-f90_7.0-dso RUNNING, CASENAME: engn Child process exited unexpectedly 2 Abort - core dumped PNP: Shutdown [2005-07-19-10:13:09] Execution aborted by request (SIGABRT) after 100 seconds.
please let me know what could be the prolem.
Thanks
Antony
parallel processing V 3.24 Phil D Siemens 3 November 10, 2007 04:31
Parallel processing in star3.24 Antony Siemens 2 February 15, 2006 11:17
Parallel processing Phil FLUENT 1 May 27, 2004 07:18
Parallel Processing bostandoust Main CFD Forum 3 July 27, 2003 13:35
convert of file from star3.05 to star3.1 Rachid Siemens 2 March 3, 2000 10:11
