Home > Forums > CD-adapco
How to fix negative volume cells etc.
Old   July 18, 2005, 18:20
Default How to fix negative volume cells etc.
Harry
hi. I am now using es-aero advanced mesh wizard to generate volume meshes and want to learn how to fix Negative volume/Zero face area/Tetrahedral Quality failure/Problem cells. Thanks you.
- Harry
Old   July 19, 2005, 00:53
Default Re: How to fix negative volume cells etc.
james
first execute the cell check foe negative volume with the option of putting the failed cells in a cellset. then type the command : cflip cset from the command prompt.I think this will work.
Old   July 19, 2005, 01:39
som
Again u can also run check for right handed cells. fix them as left handed.
Old   July 19, 2005, 02:34
bv
by changing the vertex postition also u can improve the quality of negative volume cells
BV
Old   July 19, 2005, 10:27
Harry
The problem is I have already did so, but the negative volume cells still exists. and these negative volume cells may also have some other failures, like zero face area or bad tetrahedral quality.
and what about fixing problem cells in the run check panel of proam/es-aero?
Old   July 19, 2005, 10:29
Harry
could you please give me more details about how to fix those cells in this way? if you'd like, you can also email me. thanks a lot.
Old   July 19, 2005, 14:05
paul
You might want to try not worrying about them and letting the ES-Aero geom write button, with highest repair level, take care your bad cells it just deletes them.
Old   July 24, 2005, 07:17
Hubert Janocha
- take care of too high warpage angel. When the cell is much too twisted, you problem arise from this, even when the cell orientation is OK.
- in generall delete all cells with double vertices, and generate a new one for this.
- If cflip don't works, than the same as above, delete the cell and generate a new one.
Thread Tools
Trackbacks are On
Negative densities at more than 100 cells Luke CD-adapco 5 December 2, 2008 05:14
Problems with negative volume cells Shashank CD-adapco 2 April 4, 2007 18:24
zero or negative volume cells giorgio CD-adapco 0 March 4, 2006 12:03
About negative volume of cells! xhliu1 CD-adapco 0 April 15, 2005 23:49
negative cells Armin Gips FLUENT 0 January 28, 2002 02:27
