-   CD-adapco (
-   -   Comet FSI (
Erik July 19, 2005 16:23
Comet FSI
Hi, I'm new to CFD and am working on a fluid structure interaction problem using Comet. Basically, the problem is airflow over a flat plate with a small cylindrical piece of rubber sticking up from the plate, perpendicular to the flow. I created a large flow domain of air and then the steel plate domain and the rubber cylindrical domain within the fluid domain. I'm not sure which user programming files I need to modify (i.e. umovgr, mycommand, file_name.command, etc). I tried following the FSI tutorial, but cannot understand well enough to get it to work. Any help or web links would be appreciated.
