July 21, 2005, 04:15 |
error during generate mesh in stardesign
Hi,all!
When I generate volume mesh in stardesign there is error: DBS Error: DBS:pen; **ERROR - Database is currently locked for file tmp_stardesign/Fluid.dbs database 22. Can anyone tell me what is the problem and how I can solve it? Thanks! |
July 29, 2005, 08:59 |
Re: error during generate mesh in stardesign
Check the file "procadmesh.log" inside the tmp_stardesign directory. You might find that the volume meshing failed at some point when STAR-Design was running AMMBATCH. If it has, you will need to vary some of the meshing parameters to get round the meshing problems.
StarDesign preprocessing error | Nick | Siemens | 0 | May 24, 2008 22:56 |
Volume mesh problem in STARDESIGN | Jaedal | Siemens | 2 | October 17, 2007 09:23 |
Need someone to generate mesh | RA | FLUENT | 7 | May 4, 2007 11:36 |
Mesh in stardesign to starcd! | xhliu1 | Siemens | 2 | July 6, 2005 23:06 |
transfer mesh in stardesign to starcd | xhliu1 | Siemens | 1 | June 19, 2005 03:35 |
