Visualization of baffles with Tecplot
Old   January 31, 2006, 04:45
Default Visualization of baffles with Tecplot
Tunc
Hello everybody,
I' m running an analysis with StarCD. During the post-processing, I can not visualize the baffles as boundary with Tecplot. Could anybody suggest a solution or may be a trick for this?
Thanks, Tunc
Old   January 31, 2006, 18:28
Default Re: Visualization of baffles with Tecplot
Ed
You can export the surface cells and put them in a separate Tecplot zone.
Old   February 1, 2006, 09:02
Tunc
Ok. But how can I do that with StarCD? Or you mean to export surface cells inside Tecplot?
Thanks for your help. Tunc
Old   February 2, 2006, 11:05
Ed
When you export the results from ProStar, only the fluid cells are exported. The baffle cell table will have to be separately exported, and appended to the star.dat file as a second zone, referring the original vertex set. I usually write the complete star.cel, and star.vrt file, along with the data I want. Then I use an external application I put together to sort the cell types and write them out into a Tecplot file, sorted by zones.
Tecplot: Multi-Block Visualization Sue Tecplot 6 April 10, 2007 15:53
Baffles Siddharth Siemens 2 June 28, 2006 12:52
