"Spherical coordinate mesh" error !!!
Old   September 14, 2005, 03:31
Default "Spherical coordinate mesh" error !!!
bk
ctab,10,solid,3 ctname,10,junction csys,3 vc3d,0,15,5,0,360,10,-90,90,15,3 cset all cplo
I mesh spherical grid with radius=15.
But in Tool>>Check tool, I did some checking mesh in "Aspect ratio" option. Then I had error message, but these errors didn't apperar by changing the limit of aspect ratio. When I draw the cells with errors in cell set, I had two cones shpae.
How do I do?
Old   September 14, 2005, 09:52
Default Re: "Spherical coordinate mesh" error !!!
Robert
When you build a mesh with the vc3d command using spherical co-ordinates the mesh may not be full connected at its ends. Therefore you will see errors referring to collapsed faces or aspect ratio.
To correct your mesh after the vc3d command use the following vmerge all ( this is dangerous but works in this scale of model) cfix,all,,,fix ( this corrects the cell definitions )
You should then be able to geom write without problem although this is a very course model!
spherical coordinate system in Fluent Amir FLUENT 1 March 8, 2015 12:25
Stability in spherical coordinate Mohsen Mahbubi Fard Main CFD Forum 3 September 7, 2010 09:02
[blockMesh] Spherical coordinate system ehsan_vaghefi OpenFOAM Meshing & Mesh Conversion 0 September 3, 2008 22:31
Gambit - Spherical mesh Shane FLUENT 2 June 23, 2003 20:39
Refine mesh in cylindrical coordinate Moussa Diarra Siemens 4 August 9, 2000 00:46
