Home > Forums > CD-adapco
Transient case cannot convergence?
Old   August 1, 2005, 02:26
Default Transient case cannot convergence?
Kevin
An transient problem cannot convergence.
What should I do next?
How to modify the model?
Old   August 1, 2005, 14:52
Default Re: Transient case cannot convergence?
CHELSA
Hey Kevin,
I was under the impression that transient keeps changing with time : correct me if I am wrong. Is there any special case you are running? Can you explain the problem.
Regards
Old   August 1, 2005, 21:41
Kevin
Hello,CHELSA ,
There are two large scale box passing each other in this case. Box is 1m*0.4m*0.3m, is filleted .The velocity of the two box is respectively 50m/s and -50m/s. It is versy simple ,but convergence is difficulty to arrive.
I changed the delta time ,but it still divergenced.I 'am confused for the case,what should i do next?
Old   August 1, 2005, 22:29
som
Is it cell activation and deactivation?
Old   August 2, 2005, 16:48
CHELSA
Hey Kevin,
Looks like it is a case of large tolerences. How much did you give? Try something like 0.001 or closer and also are your momentum equations converging?
Old   August 3, 2005, 07:35
Kevin
To Som yes,just as you said.
To Chelsa
Thanks ,I will try again!
Thread Tools
Trackbacks are On
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
Transient Case MAB CFX 7 August 13, 2008 07:52
Convergence in transient case Hamodi CD-adapco 3 February 1, 2007 05:10
Residuals for transient case suti FLUENT 0 September 30, 2005 04:31
UDF about transient case Jason FLUENT 1 May 12, 2004 05:05
