[Sponsors] | |||||
bcheck,all BEGIN CHECKING ALL BOUNDARIES
PRELIMINARY SEARCH FOUND: 37259 FLUID CELLS, 0 BAFFLES CONJUGATE HEAT TRANSFER TURNED OFF - ANY SOLID CELLS WILL BE IGNORED BEGINNING CONNECTIVITY SEARCH 2000 CELLS PROCESSED 4000 CELLS PROCESSED 6000 CELLS PROCESSED 8000 CELLS PROCESSED 10000 CELLS PROCESSED 12000 CELLS PROCESSED 14000 CELLS PROCESSED 16000 CELLS PROCESSED 18000 CELLS PROCESSED 20000 CELLS PROCESSED 22000 CELLS PROCESSED 24000 CELLS PROCESSED 26000 CELLS PROCESSED 28000 CELLS PROCESSED 30000 CELLS PROCESSED 32000 CELLS PROCESSED 34000 CELLS PROCESSED 36000 CELLS PROCESSED 223554 CELL FACES TO PROCESS **WARNING - BAFFLE CELL 1 IS NOT ATTACHED TO ANY FLUID OR SOLID CELLS. BAFFLE IGNORED. **WARNING - BAFFLE CELL 3 IS NOT ATTACHED TO ANY FLUID OR SOLID CELLS. BAFFLE IGNORED. **WARNING - BAFFLE CELL 7 IS NOT ATTACHED TO ANY FLUID OR SOLID CELLS. BAFFLE IGNORED. ---------------------- **WARNING - BAFFLE CELL 37258 IS NOT ATTACHED TO ANY FLUID OR SOLID CELLS. BAFFLE IGNORED. FIRST PASS COMPLETE. FINAL COUNT IS: 37259 FLUID CELLS, 0 BAFFLES 0 TRIM CELLS, 0 TRIM COUPLES BEGINNING SEARCH FOR INTERNAL CUTS. 37259 CELLS TO SEARCH. 2000 CELLS SORTED 4000 CELLS SORTED 6000 CELLS SORTED 8000 CELLS SORTED 10000 CELLS SORTED 12000 CELLS SORTED 14000 CELLS SORTED 16000 CELLS SORTED 18000 CELLS SORTED 20000 CELLS SORTED 22000 CELLS SORTED 24000 CELLS SORTED 26000 CELLS SORTED 28000 CELLS SORTED 30000 CELLS SORTED 32000 CELLS SORTED 34000 CELLS SORTED 36000 CELLS SORTED SECOND PASS COMPLETE - 37259 FLUID CELLS FOUND ALL BOUNDARIES CHECKED SUCCESSFULLY BOUN*> ================================================== ================================== **ERROR - CELL 37257 HAS PHYSICAL BOUNDARIES ON ALL SIDES **ERROR - CELL 37258 HAS PHYSICAL BOUNDARIES ON ALL SIDES **ERROR - CELL 37259 HAS PHYSICAL BOUNDARIES ON ALL SIDES BEGINNING GEOMETRY WRITE TO FILE star.geom NEIGHBOR AND BOUNDARY LISTS - WRITTEN NUMBER OF CELLS WITH EDGES/POINTS ON THE SURFACE = 37259 GEOMETRY WRITE COMPLETED - FILE CLOSED BEGINNING TO WRITE STAR PARAMETER FILE parm.inc STAR PARAMETER FILE WRITTEN TO FILE parm.inc **PLEASE NOTE - MANY OTHER FUNCTIONS RELY ON SAVING THE .mdl FILE AFTER WRITING THE GEOMETRY FILE - YOU SHOULD SAVE NOW. |
Are you by any chance using v3150A on a linux machine running Red Hat Enterprise? If so, there seems to be no cure for this problem. You can upgrade to v3.2 or use another OS.
thank you!
I am using V3.2 on WOW Paran2 linux machine and more.. finally.. I found this problem in this cas, I made my mistake at making cell generation process(making patching and then shells and...etc) the mistake on the process making the cell caused that made baffle on each cell surface, which will not be appeared by "count cell" command anyway, cell-making process is difficult to me.. thank you for your reply.. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| un-physical temperature value | Julien Ramousse | CFX | 5 | January 2, 2009 05:05 |
| Is that physical? | Giovanni | Main CFD Forum | 3 | January 10, 2008 18:55 |
| physical model with cfd | Beno | Main CFD Forum | 0 | August 30, 2004 06:06 |
| Physical Velocity !!!! | pk | FLUENT | 0 | June 19, 2003 14:22 |
| Physical Timestep | Ted Crilly | CD-adapco | 2 | February 18, 2003 04:05 |
