modifying the damping function(STAR CD)
Old   August 11, 2005, 05:24
Default modifying the damping function(STAR CD)
Ibrahim
Hi All If (kindly) any1 can really spend few minutes from his value time to help me; how to modify the damping function in LRN k-epsilon model. or making 'Cmu' as a function of another parameter. ( overwhole, changing the turbulent viscosity formula). cheers
Old   August 15, 2005, 06:40
Default Re: modifying the damping function(STAR CD)
4xF
I guess you want to modify the log-law, so you should be able to come to your goals by using the STAR-CD user subroutine ROUGHW(ELOG,YLAMS,CONST,YPLS).
Hope this helps...
Old   August 15, 2005, 10:01
Ibrahim
Thanx for your reply, Actually, I want to test another damping function using the same LRN k-epsilon model. Because The problem (Non-Newtonian case) I have , needs to have more damping than the Standard one. cheers
viscous damping function maria Siemens 0 August 21, 2006 01:31
viscous damping function maria CFX 0 August 21, 2006 01:30
viscous damping function maria FLUENT 0 August 21, 2006 01:29
viscous damping function maria FLUENT 0 August 16, 2006 07:52
Wall Damping Function Apurva Main CFD Forum 4 May 14, 2003 11:34
