Home > Forums > CD-adapco
Help please - momentum source
Old   August 16, 2005, 22:42
Default Help please - momentum source
Sheila
Hi everyone,
I am trying to modify the turbulent viscosity that goes into the momentum equation without effecting its value in the turbulence equation. It has been suggested by support that I should write the diffusion terms as a source term to cancel the existing terms and implement my values. For example, if I want to change the viscosity to SCALAR*vist then I should do the follwoing,
(S1U-S2U*UP)*(SCALAR - 1)
I have been trying to implement the above without any success. The solution diverges in any attempt to do so.
Has anyone done anything similar to the above or can you suggest anything else. Re-writing the turbulence as scalar does'nt work( I wasted 3 months trying it only to be told by support that it cant be done... )
Please help me solve this...
Old   August 17, 2005, 05:46
Default Re: Help please - momentum source
Ibrahim
me too, I am trying to modify the turbulent viscosity in k-epsilon model , I tried an old version of Star-CD which contains Varcmu.f ( variable C_mu)soubroutine, but actually it does not work at all. I am planning to call the S.CD provider. BUt as u said it seem to be long story(-) cheers
Old   August 22, 2005, 11:34
4xF
I think that it is dangerous to modify the source term S1U that way, because the source term should have also the contribution of the pressure gradient. Ask support to send you the expression they use for evaluating the source term due to the turbulent viscosity approximation i.e. div [ mu_t * grad (Vel) ]. They will have to take a look at the source code, but it should be feasible. Ask them for the explicit formulation. That will allow you to correct the source term in a an explicit manner (which should be stable) and disable the source term at the same time by multiplying the expression by -1 and adding it to S1U, etc...
Hope this helps...
Old   August 28, 2005, 22:17
Sheila
Hi 4xF,
thank you for your response. Anctually we did go and see someoen at STAR about it, and, armmmm, well it seems like it was'nt an easy job... They gave some kind of 'deferred correction' interms of nodal velocity (Up) and it did'nt work
Sheila
Old   August 30, 2005, 02:24
zxaar
Can you drop me a page's write up how you want to modify the viscosity, i do have a steady state solver, if it is possible i will hard code that in my solver and give you the exe to work on with. You might have to wait 10-15 days as i am in process of transfering code from my old solver (that has k-e and k-omega models) to new code. So if you write it up in sufficient details (what you are exactly trying to do), your problem might be solved otherwise.
my email is
zxaar@yahoo.com
Old   August 31, 2005, 22:30
zxaar
did you get the reply email i wrote to you ????
Thread Tools
Trackbacks are On
momentum source zht77 FLUENT 1 April 4, 2013 22:30
Momentum source...>>>Please Help...! sushii FLUENT 0 October 15, 2007 04:16
Momentum source Jackie CFX 0 February 16, 2003 02:16
momentum source Jackie CFX 7 January 31, 2003 02:13
Momentum source HDZ FLUENT 7 October 15, 2002 04:28
