Home > Forums > CD-adapco
VIEW FACTOR CALCULATIONS
Old   August 18, 2005, 10:13
Default VIEW FACTOR CALCULATIONS
Cedric
Hi all,
I am facing problems with radiation patches: I am working with a model with radiatioan activated, defined patches on the boundery conditions... and it works fine (geom file is OK, and calculation of *.vfs file just befor the solvinng phase works (View Factor Calculations)) Now I want to refine the dimenssion of my patches, lets say from 100 to 50 or even 20 (I did try both). Then if I launch the updated model, the solver does not actually run as the file *.vfs is not written! The calculation of the view factor gets stuck half way through... I frequently ask the support but on that issue got no explaination so far.
Hopefully some of you guys already encounter the same problem and could give me a hint...
Thanks in advance,
Cedric
Old   August 22, 2005, 09:39
Default Re: VIEW FACTOR CALCULATIONS
carno
View factor calculation requires considerable time and *.vfs file is also very large. Just check if the file size is going beyond 2GB. If yes that can be a problem on windows system.
Old   August 22, 2005, 11:22
Cedric
Thanks for the answer, I know the *.fvs file can become quite large (I actually have a calculation running with 4.7GB file under LINUX). I also let the process run more tan one hour, to see if it was time dependent. But so far, it just get stuck half-way. Anyway... I'll just have to find my way around that. Cheers
Thread Tools
Trackbacks are On
Axisymmetric View Factor in FIDAP romz FLUENT 0 May 8, 2006 03:57
View Factor calculation in Fluent Markus FLUENT 0 November 13, 2005 21:59
Fluent - View Factor for s2s radiation Markus FLUENT 1 October 16, 2005 01:33
Fluent View Factor Exportation Scott FLUENT 2 July 25, 2005 01:38
Radiation view factor Lemas Main CFD Forum 4 September 14, 2003 00:17
