wall data
Old   August 24, 2005, 11:08
Default wall data
Pete
Hi is there a way to get wall data of a run which did not finish properly? I think y+, htran and Twall are only processed and written to the .pst after the run is finished.
Old   August 24, 2005, 11:48
Default Re: wall data
William Blake
You can do a restart run with zero iterations to get a correct *.pst file.
Another option is to stop a running calculation with "touch ABORT".
Old   August 25, 2005, 04:06
PETE
Problem is that I read wall temp from a tmp file which I cannot access after the run crashes. Is there another possibility?
Wall temperature data in helical pipe! Wael Siemens 3 November 1, 2014 10:42
Unsteady Wall Shear Stress Data Repoting Arash FLUENT 1 February 13, 2008 14:36
The problem of wall data getting when postprocessi WIlliams Siemens 4 March 6, 2006 10:14
read in wall data Ethan Siemens 0 March 29, 2003 15:19
HELP: Wall variable temp is not on the data file? Jiaying X Siemens 4 September 19, 2002 13:30
