What are trimming loops in pro-surf?
Old   August 31, 2005, 04:15
Default What are trimming loops in pro-surf?
Alicia
Can someone possibly give me a definition of trimming loops in the pro-surf program?
Old   September 1, 2005, 15:55
Default Re: What are trimming loops in pro-surf?
staruser
A trimming loop is a generic surface limited by lines/edges. If you have errors in trimming loops, you have errors in some surfaces. Simple shapes can be created in pro-surf, but you might want to go back to the CAD program and have a closer look at the places the errors occure. Sometimes an automatic fix will clean the surfaces, and it's always good to automatically fix, increase the tolerance (e.g. by 2x) and rerun the automatic fix and so on. With "vdis xx xx" you can get an idea about the distance between two vertices so that you know approx. how far you want to increase the tolerance. When you select points you will see the vertex number in the select window or in the main window.
Hope this helps!
where is 'max continuity loops' Xueying CFX 2 May 20, 2021 07:23
Loops per iteration Anon CFX 3 December 11, 2007 16:29
Face-loops in GAMBIT Kasper Skriver FLUENT 0 May 29, 2006 08:00
Pro surf Konstantinos Siemens 11 May 10, 2006 08:32
Trimming surfaces Heywood CFX 3 April 9, 2004 05:39
