Home > Forums > CD-adapco
star-cd save problem
Old   September 7, 2005, 04:48
Default star-cd save problem
fevzi topcu
hi, I am a star-cd v3.24 user and I want to save my file on previous vesion, which command should I use? can you help me... thanks
Old   September 7, 2005, 11:18
Default Re: star-cd save problem
Thomas
you can always do a 'save coded'
this generates you a couple of files and an input file (*.inp). This input file you can read in previuos versions of prostar via the read file option.
Normally this works fine. There might be some minor problems, e.g. when you defined turbulence model in V3.24 which is not available in older version. So you should check you settings afterwords.
Thread Tools
Trackbacks are On
Linux parralel command line auto-save problem. Joe FLUENT 4 January 10, 2008 12:41
FoamX save case file problem rchenglong OpenFOAM Pre-Processing 0 September 26, 2007 20:40
Save file problem phinix FLUENT 0 February 8, 2007 01:07
How save selection in Star-CD? SanyaKrasnoyarsk CD-adapco 2 February 1, 2006 05:37
Is it the bug to save file in star-cd 3.10a raymond CD-adapco 3 September 21, 2001 02:09
