September 10, 2005, 06:02 |
new user please help
I am fixing the mesh problems. Initially it is giving 6 unresolved elements.No other problem in mesh. As i fix them it is giving about 112 failed elements but only 50 elemtns in CPMATCH criteria no other error. Please guide me how should i over come CPMATCH problem
thanks |
September 10, 2005, 12:06 |
Re: new user please help
Check all couples and use the option to create a new couple set with all failed couples. Delete your cell (and vertex) cell and open Lists > Couple List. Start with the first couple and put master cell into cells set. With "plfa on" you can check on which cell face the couple is. Then extend the cell set with the first slave, check it visualy; then add the next slave etc. If a slave is missing, you can select all vertices on the cell face and use "cset add vset all" or "cset add vset any" if "all" fails. In the couple list panel you can add slaves to the active couple.
September 12, 2005, 00:10 |
thanks for help staruser now it is giving all cells as disconnected cells
September 12, 2005, 16:49 |
Disconnected means that you have more than one part in your model. Do you want that? If you use Tools > Check > Connectivity, you whould get 1 or -1 in post register 4. If you turn on contour plot you should be able to get a view of the problems.
new user | hsn | CFX | 1 | June 16, 2007 09:54 |
New user... | rajesh m n | CFX | 1 | November 24, 2006 00:26 |
new user needs help! | Sbai donia | FLUENT | 1 | May 5, 2006 07:21 |
New user | Faris | FLUENT | 0 | February 3, 2006 17:17 |
User viscosity routine and user scalars? | Jeff | Siemens | 3 | January 6, 2003 05:26 |
