Vacuum pumpdown simulation
Old   September 28, 2005, 16:17
Default Vacuum pumpdown simulation
Derek Coon
I am trying to simulate a vacuum pumpdown on a complicated geometry but having little luck. I want the pressure in the cavity to start at 100,000 Pa and pump down (transient) to 20,000 Pa (absolute), but Star is changing the pressure across the entire field during the first iteration. I'm currently using a time step of 1e-6, but have even tried 1e-9 and it doesn't matter. Conceptually it's very simple, a cavity with a single pressure boundary, but the results are disappointing.
Any ideas on what I could be doing wrong?
Old   September 29, 2005, 13:55
Default Re: Vacuum pumpdown simulation
Pauli
Sounds simple enough.
Are you using a time dependant pressure boundary? How is it prescribed - bcdefp.f or a table?
Where is your reference pressure specified?
Are you looking at absolute pressure or relative pressure?
Old   September 29, 2005, 16:52
Derek Coon
I thought so too... until I tried it.
Physically the geometry is very small and we have a large vacuum reservior so I am just changing setting the pressure boundary on the GUI to the new value (-80kPa relative).
I believe my reference pressure (which is 100kPa absolute) is specified as one of the cells in the domain. (I say believe because now I am unsure of how the reference pressure works.)
I don't particularly care if it is absolute or relative. Perhaps I don't understand the question though.
Vacuum pump simulation Alasdair Main CFD Forum 3 March 3, 2011 00:00
CFD at vacuum Jiri Novak FLUENT 1 August 9, 2007 14:09
supersonic jet into vacuum lee FLUENT 0 March 27, 2007 09:54
Radiation - vacuum Peter Main CFD Forum 1 January 24, 2006 09:41
fluid vacuum terry j stengel Main CFD Forum 0 March 28, 2002 23:06
