how to add liquid rotate speed(w) ?
Old   September 20, 2005, 21:49
Default how to add liquid rotate speed(w) ?
ATao
i found that there are only U、V and W,but how to add liquid rotate speed(w)?i use STAR-CD3.15,it hasn't gravity folder,how to install "g" ?
Old   September 21, 2005, 05:32
Default Re: how to add liquid rotate speed(w) ?
John Luo
For gravity in v315, in PROSTAR GUI, Thermophysical Models=>Liquids and Gass=>Buoyancy and Body Force.
For rotation, there are many ways: if the whole system is rotating, you can solve the system in the single rotation frame. If only boundary such as wall rotates, you can input rotational speed at respective boundary region. For more complicated rotating system, you can use multi-rotating frames or sliding mesh.
need references for Liquid-liquid two-phase flow qunwuhe@hotmail.com Main CFD Forum 1 December 8, 2009 03:32
UDF to rotate Jon FLUENT 3 July 20, 2005 08:42
Rotate image Daniel Bruno FLUENT 4 May 25, 2001 07:42
ARTICLES AND WORKS CONCERNING CFD OF LIQUID-LIQUID DISPERSION AND DROPS SIZE IN AGITATED SYSTEMS.. tim Main CFD Forum 1 June 22, 1999 08:07
