September 29, 2005, 11:31 |
Warning # 090
Hi All,
I was runnning a combustor model in STAR CD 3.15 but when I am running the same model in STAR CD 3.24, I am getting following warning. *** WARNING #090 *** VALUE ELOG*YPLUS OR ELOG*EFFVIS/(CAPPA*VISCOS) IS LESS THAN 1.1 AT 200 CELLS. UPLUS=YPLUS LAW IS USED. IF THIS SITUATION PERSISTS, INCORRECT RESULTS MAY BE OBTAINED. The results vary by about hundred degrees, higher temperatures are obtained from 3.24. Thanks, |
November 26, 2005, 01:27 |
Re: Warning # 090
If this warning persists after 200 iterations then you have to refine the mesh near wall region(I am assuming that you are doing a steady state analysis)
DB |
Warning 046, what does it mean? | SAKTI | Siemens | 1 | July 31, 2008 12:14 |
warning #064 | ema | Siemens | 1 | August 25, 2005 05:45 |
warning # 90 | vishal | Siemens | 1 | August 11, 2005 09:19 |
*** WARNING #052 *** | Cirilo | Siemens | 1 | July 27, 2005 08:34 |
Warning | Paco | Siemens | 0 | June 23, 2005 02:33 |
