Home > Forums > CD-adapco
applying post data as b.c on some other model
Old   October 4, 2005, 00:42
Default applying post data as b.c on some other model
manohar
can anybody know how to give the temperature on the walls(results) from one model as boundary condition on some other model(of similar geometry).
first of all is this a possible case or not?
thanksalot
Old   October 4, 2005, 07:59
Default Re: applying post data as b.c on some other model
William Blake
It is possible but requires some work (macros...). You should ask the support for help.
This might be a good topic for Dr. Mesh or adapco-online once it is back again.
Old   October 5, 2005, 13:01
Ted Crilly
its sounds very interesting what would be the reason for doing this?
are your wall boundaries normally fixed temperature ? so that the temperature does'nt vary over the surface?
mind you I have seen some models results with temperature varying over the surface, i believe this is where the user has not setup fixed surface temperature boundaries in their model and it may not be correct or accurate
any others got views on this?
Old   October 10, 2005, 06:38
bv
could you please eloborate the problem further so that i can try to help u.
BV
Thread Tools
Trackbacks are On
Applying a turbulence model to rhoCentralFoam srinath OpenFOAM Running, Solving & CFD 10 February 8, 2012 07:07
applying profile data as a boundary condition vadivel CFX 1 June 9, 2007 07:11
post data starcd_learner CD-adapco 0 February 1, 2006 12:24
applying results as b.c on some other model manohar FLUENT 3 October 10, 2005 07:03
Post data Joel CD-adapco 3 November 4, 2002 06:58
