November 14, 2005, 01:03 |
Porous Media
I have the following relation of pressure drop vs velocity for a tube bank of a heat exchanger in x coordinate: dP/X=-1.6909*v^2-0.0762*v . Do i have to assign to alphax1,alphax2,alphax3=-1.6909 or only alphax1 so alphax2,alphax3=0, same for betax1,betax2,betax3.
Thanks for your help |
November 15, 2005, 10:14 |
Re: Porous Media
Hi there,
You've got a channel flow, so is clearly a case of orthotropic resistance. aphax=1.6909 in the flow direction betax=0.0762 in the flow direction In the cross-flow direction (y and z), assign big numbers. Good luck! |
November 17, 2005, 00:48 |
Re: Porous Media
Hello
I am also modelling same type of case(shell and tube HX 1*2)i am using alfax=5.6 e4 betax=5.6e4 alfay=5.6e4betay=5.6e4 and alfaz=0.5 betaz =0.4. do these values seem to be right. please comment. |
November 17, 2005, 04:22 |
Re: Porous Media
The relation which you have is non linear whereas alpha and beta appears in linear equiation. Ensure that the the LHS is a derivative, otherwise you need to differentiate the expression to get the correcto values of alpha and beta.
Secondly if alpha y and alpha z is zero means there is no resistance in y and z direction. |
November 17, 2005, 04:24 |
Re: Porous Media
Hi there, Well, I'm not an expert on this, but again if it's a channel flow, and the flowing direction is on the z axis then you should be allright. Another issue is where did you get those values from, etc...
Best regards, Esti |
Display Modes | |
Free media&porous media.Big changes in properties. | Isi | Main CFD Forum | 1 | July 14, 2008 08:18 |
porous media | mikezhang | Phoenics | 2 | September 21, 2002 22:10 |
Porous baffle and porous media | Jan | Siemens | 0 | June 8, 2002 10:23 |
Porous media | James Hampson | FLUENT | 1 | January 12, 2001 13:29 |
Porous media | Alberto | FLUENT | 4 | July 20, 2000 06:47 |
