Home > Forums > CD-adapco
free surface outlet
Old   October 17, 2005, 01:55
Default free surface outlet
novice
I am doing a free surface analysis. It is a manifold supplying coolant to the punch die assembly. Coolant is not fully filled in the manifold all the time (free surface). There are five outlets. I am not understanding what BC I should use for the outlets. Pressure or split outlet or any other. I do not know the flow split. So when I give atm pressure it diverges after 2 timesteps. If I use flow split outlet based on their area, run does not start at all, it comes out before starting. (some OS error)
Kindly help. Thanks in advance.
Old   October 19, 2005, 05:59
Default Re: free surface outlet
4xF
Have you tried to use piezometric pressure with environmental option on?
Hope this helps....
Old   October 19, 2005, 07:31
novice
Thanks 4xF. It is running with same pressure BCs now after reduction of pressure under relaxation factor.
Thread Tools
Trackbacks are On
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
Free surface pressure outlet nico FLUENT 0 November 9, 2004 16:29
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
