Home > Forums > CD-adapco
about tutorials 11
Old   October 18, 2005, 18:32
Default about tutorials 11
tiny
Dear all
I want to try tut11.
I consult this tut11.
Then I use "command" method not subroutine.
When I start to analyse this case,the windows display this error.
Who can tell me,what's wrong??
How to solve this problem?
thanks ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~
PNP: Initialized [2005-10-19-06:16:10] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "tiny,1" resource (1 process). PNP: Overload STAR master processor with external moving mesh code. PNP: Assigned "tiny,1" to STAR solver (1 process). PNP: Assigned "tiny,1" to external moving mesh code (1 process). PNP: Analyzing User coding in "ufile" directory. PNP: compiling /d//bin/f77 -O2 -f -v -N3 -N26 -N25 -Q101 !Q19 -c uparm.f -o windows-x86-absoft_8.2a-dso/uparm.obj PNP: /c/Program Files/CD adapco/STAR-CD/bin/../STAR/3.22.000/windows-x86-absoft_8.2a-dso/bin/star: /d//bin/f77: No such file or directory PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f". PNP: ==> Please check the compilation error messages.
D:\STARhomework\tut\tut11-1\test1>
Old   October 18, 2005, 18:39
Default Re: about tutorials 11
tiny
I compile the error information again.
Old   October 19, 2005, 07:33
carno
Hope you have absoft fortran installed on your system. Set the environment variable absoft75 = <ur path>
check ur user subroutine independantly in absoft editor.
Hope this helps
Old   October 19, 2005, 16:39
staruser
Look at the line:
STAR-PNP is looking for an absoft compiler at d:\bin. Is it installed there? What if you open a command prompt and enter "f77"? Is the command recognized? You need to set the environment variable ABSOFT to point to the directory where absoft is installed, e.g. "d:\program files\absoft" and add "%ABSOFT%\bin" to the path. After you've done this, reopen a command prompt and reenter "f77".
Hope this helps.
Thread Tools
Trackbacks are On
Tutorials on MHD Sridhar FLUENT 4 June 22, 2011 14:41
Tutorials, where? Rogerio Fernandes Brito FLUENT 0 October 29, 2008 14:28
UDF tutorials anup FLUENT 5 March 11, 2008 04:04
Tutorials Gaurav Ranzekar CFX 1 November 30, 2005 23:42
Tutorials Jennifer Haque CFX 0 January 17, 2002 08:16
