Home > Forums > CD-adapco
non-linear BC and source
Old   October 22, 2005, 00:34
Default non-linear BC and source
Murali
Does anybody know how to program a non-linear boundary condition for a user-defined scalar ? Consider this example:
d^c dc
--- + (--)^2 = 0
dx^2 dx
With boundary condition:
@x=0 C=0
dC
@x=1 -- = C^2 -----> Non- linear boundary condition
dx
The analytical solution of this is :
e(1-exp(-x))
(e-1)^2
SORSCA with POSDAT works fine for modeling source terms. But how to model a non-linear BC ?
It seems to be not working through BCDEFW and POSDAT. I tried to put it as source in the last cell,
but it fails too. Please let me know.
Old   October 22, 2005, 06:37
Default Re: non-linear BC and source
DenizeN
But what is you problem ? Howe are you set the BC ? And what is not working ?
Old   October 22, 2005, 13:18
Murali
My problem is as follows:
BCDEFW is the subroutine where we set user defined scalar value. since my boundary condition is non-linear I have to use POSDAT to calculate the non-linear value and pass this value to BCDEFW. i.e in BCDEFW I would have some code like:
Code in POSDAT:
COMMON /MYSCALAR/SCALVAL
IF (IBND .EQ. -42) THEN
SCALVAL = T(ICELL,1+1)^2
END IF
(IBND is the boundary number)
Code in BCDEFW:
IF (IBSTAR .EQ. 42) THEN
SCALAR(01) = SCALVAL
END IF
The SCALVAL is originally calcualted using POSDAT at level 1 and passed by COMMON block to BCDEFW. SOmehow, this does not seem to yield proper results (convergence is attained though). Is there anything more to do when I write non-linear boundary conditions ?
Old   October 24, 2005, 13:49
DenizeN
Whay You are not write:
Code in BCDEFW: ============== COMMON /MYSCALAR/SCALVAL IF (IBSTAR .EQ. 42) THEN SCALAR(01) = TC^2 END IF
or something else like this ? why you use POSDAT ?
what function you want to calculate ?
may be you write what are you want to do. You must set function on boundary type f(Temperature) ?
Old   October 25, 2005, 18:01
Murali
Dear Denizen,
When I tried that it is always diverging. Can you do a favor ? Can you just send me a small (working) example of STAR-CD subroutine code where you have succesfully implemented a non-linear Bouncary condition. say for example dc/dx = c^2 please ?
It will be must appreciated.
Old   October 27, 2005, 07:29
DenizeN
I have'not prepeared code to you situation. But i do not see any problem to calculfnt you BC.
Code in BCDEFW: ============== COMMON /MYSCALAR/SCALVAL IF (IBSTAR .EQ. 42) THEN SCALAR(01) = e(1-exp(-x))/(e-1)^2 END IF
but you are must set offset to you BC this analitical solution means x=from 0 to .... but you BC is located somwhere x=from 45.54 to 99.34 ensure that it is all fine
Thread Tools
Trackbacks are On
linear and areal pollutant source Riccardo Buccolieri FLUENT 1 February 27, 2014 08:57
contribution of convective source in total source? Antony Phoenics 4 July 30, 2008 05:15
high positive linear source term using FEM Isi Main CFD Forum 0 June 11, 2008 03:46
Linear Solvers Sachin Main CFD Forum 0 May 6, 2006 12:07
where do I find a source code to solve a linear ma Wang Main CFD Forum 2 May 6, 2004 13:28
