under relaxation factor
Old   November 22, 2005, 22:58
Default under relaxation factor
novice
I am running a transient analysis with free surface. My run is diverging after some time, so I have reduced the time step. But this has very less effect on divergence. When I reduced the 'under relaxation factor for pressure correction' the run is running fine. But after some time it again diverged. So I reduced it further. So I just want to know how low I can go there? WHat is the effect. Thanks all
Old   November 26, 2005, 01:10
Default Re: under relaxation factor
DB
Normally under-relaxation factor should be between 0.8-1.0
DB
Old   November 28, 2005, 04:18
zxaar
If you case the convergence is difficult, then you could decrease the urf for pressure to 0.1 from default of (i think 0.3), and increase the urf of mom to 0.8 to 0.85. Further increase the pre and post iteration in AMG solver settings, this will keep the solver stable. If it does not help then check the skew of the mesh, the unstablity is due to this (most probably)
what is under relaxation factor? rayy FLUENT 30 September 6, 2020 01:06
relaxation factor adam Main CFD Forum 3 February 4, 2008 10:10
help in relaxation factor SONALI FLUENT 5 August 11, 2005 20:27
Under Relaxation Factor AB Siemens 0 November 29, 2004 13:56
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
