HPC with STAR-CD 3.22
Old   October 24, 2005, 11:22
Default HPC with STAR-CD 3.22
vigorzxy
When I did my simulations under a server with 4 AMD Opetran CPU, I tried the "star hostname, 4" but echoed the right-handed error (including the moving mesh in case). How should I set-up the star command to run the parallel computations? By the way, the Lagrangian multi-phase flow was also inclued in my case.
Thanks a lot!
Old   October 25, 2005, 00:36
Default Re: HPC with STAR-CD 3.22
carno
U have moving mesh. So be cautios while using HPC. You have to use manual option while giving HPC run for moving grid problems. All the moving mesh cells should be on one cpu. Read the appendix H in star userguide to use manual option. Default option is metis.
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
Star Design to Star-CD(Prostar) AB Siemens 5 October 28, 2004 12:21
