Home > Forums > CD-adapco
Modeling porous media flow in prostar
Old   October 26, 2005, 07:01
Default Modeling porous media flow in prostar
Nirmal Kumar Pathak
I am working on some problem of porous media flow in prostar(starcd). To check as a trial, I changed the values of porosity in model,but i am not getting any effect. On setting the value of porosity as zero,it should behave as a solid. but it is not showing any changes in results. kindly help me.
Old   October 26, 2005, 07:19
Default Re: Modeling porous media flow in prostar
Richard
Isn't the porosity only a factor for transient simulations? Are you running transient?
Old   October 26, 2005, 07:23
Nirmal Kumar Pathak
Ya ,some body had told me this. but then how to go for steady state problems.
Old   October 26, 2005, 08:47
Richard
In steady-state, all you are doing with a porous medium is specifying pressure-drop as a function of fluid velocity. I don't know that you could stably model a solid like this. Why do you need to?
Old   October 27, 2005, 04:30
Nirmal kumar pathak
I am modeling a shell and tube heat exchanger for getting shell side flow distribution for a steady state problem. The domain of U-tubes is being modeled as porous media .The value of porosity, i have used is 0.68(hand calculated as ratio of open vol. to total vol.)Just to check,I was trying to get the variation of results(vel. contours) with varying values of porosities(within a range of 0 to 1) keeping all porous resistance coefficient values same.According to my perception,When the value of porosity is 0.0,the domain which has been defined as porous media should behave as a solid and no flow should be able to pass across it.No change in results have been observed for different porosity values. HOW SHOULD I PROCEED???
Old   October 27, 2005, 08:02
Richard
The porosity will have no effect on the calculation as it is steady-state, which is why you get the behaviour you have found. It's not a bug - see the methodology manual. The only useful validation you can make of your porous medium is to check that pressure drop vs. flow rate is what you expect it to be (given the coefficients you have supplied).
Old   October 28, 2005, 00:35
Nirmal Kumar Pathak
hello Richard,
Thanks a lot for your replies.
Old   October 30, 2005, 03:19
limingtiger
what's the problems about my following command? i want to define the fluid with the porosity 0.5, but the result is wrong. ctab,4,fluid,7,0.5,4,1,1,1,0,off,0,light CELL TABLE NUMBER 4 IS FLUI
NAME = soil
COLOR INDEX = 7 POROSITY INDEX = 0
MATERIAL NUMBER = 4 SPIN INDEX = 1
GROUP NUMBER = 1 LIGHTING MATERIAL = 1
RADIATION = OFF
CONDUCTION THICKNESS = 0.000000
INITIAL FREE SURFACE MATERIAL IS LIGHT
MESH*> ctname,4,soil NAME OF CELL TABLE 4 IS soil
Old   November 23, 2005, 08:18
Mahesh Masurkar
This is the porosity index no. which is an integer,say 1.
You should define the porosity in the Thermophysical models-->porosity-->porosity index #1.
Mahesh
Thread Tools
Trackbacks are On
modeling the fluid flow in porous media by Fluent Mohsen Nazari FLUENT 3 November 17, 2014 08:53
modeling porous media Novice FLUENT 4 October 20, 2008 06:28
Two-phase modeling in porous media Ali Main CFD Forum 0 February 27, 2006 06:52
Help for modeling of anisotropic porous media, thx TobeFlowMaster FLUENT 10 January 31, 2005 12:13
Modeling drying in porous media Oliver Main CFD Forum 0 January 14, 2005 12:41
