Home > Forums > CD-adapco
HPC on a Linux cluster
Old   November 8, 2005, 22:11
Default HPC on a Linux cluster
Jihwan
Hi there,
Recently I set up a linux cluster consisted of 5 nodes 2 Opterons on each node. I did test run with a command like as follows:
"star 1", "star 2", "star 10"
The command "star 1" & "star 2" will run the job on the master node. My finding is that "star 2" execution time is around the half the "star 1". It makes sense. However, "star 10" execution time is nealy the same as the run time by "star 2". Can anybody explain what is happening in my trial run? One more thing. My cluster computer uses giga-bit switch and master and each slave node have enough memory larger than 24 giga bit in total.
Jihwan
Old   November 10, 2005, 11:33
Default Re: HPC on a Linux cluster
tomosada
If the hostnames of your nodes are cluster1 cluster2 cluster3 cluster4 and cluster5
The correct command you should type is
star cluster1,2 cluster2,2 cluster3,2 cluster4,2 cluster5,2
This command can drive the solver run a 10 CPU job.
you can contact your local distritube for more information.
tomosada
Old   November 22, 2005, 11:17
Ben
presumably star1 is your master node? How long is the run, what sort of load ballancing do you have and approximately how many cells are there per cpu?
Thread Tools
Trackbacks are On
how to use -ssh w/ Fluent on Linux cluster Bill FLUENT 4 April 2, 2014 00:04
cluster on Linux Ivan CD-adapco 2 December 3, 2004 12:03
LINUX CLUSTER co2 FLUENT 1 April 24, 2004 04:30
linux cluster Johan Carlsson CD-adapco 6 July 4, 2003 12:02
linux cluster Johan Carlsson Main CFD Forum 2 June 21, 2003 07:14
