turbulent transient
Old   November 24, 2005, 09:57
Default turbulent transient
david vdl
hi,
i try to simulate a trubulent channel flow with star-cd 326.
therefore i have defined the inlet- and the outletface of the channel as "cyclic". so that the velocity-distribution at the inlet-plane is tuned over to the outlet-plane. the pressure should have a constant pressure drop between these to boundaries. it is not explained in the user guide. do you know how to fix this this?
i also have an other question: the flow is transient. so i want to initialize the flow with a given velocityprofile. i tried it with a table relatetd to the material (air). should i better define the velocity for "cells"? what is the difference?
many questions, i know. but perhaps you can answer some of them. it would be great. thank you.
david von der lieth
Old   November 26, 2005, 01:00
Default Re: turbulent transient
DB
I can help you only with the second question. The best way to initialise the flow is by using user subroutine initf.f(i dont remember the exact name). I also faced the same problem and table was not working for me so I used the user subroutine and I believe that is also an efficient way.
DB
Turbulent intensity and turbulent dissipation Phil FLUENT 2 February 14, 2018 05:06
Using different turbulent viscosities for turbulent stress components braennstroem OpenFOAM Running, Solving & CFD 13 October 15, 2010 08:59
Transient Flow, Transient Pressure in Work Bench Erich CFX 1 May 8, 2007 11:55
How to set up transient BC? Sam CFX 2 March 17, 2005 21:09
transient arthur FLUENT 1 May 5, 2004 04:09
