boundary conditions
hi,
I KNOW FLOW RATE and PRESSURE DROP(BETWEEN INLET AND OUTLET) Which B.Cs. should i select. the problem is of pipe flow with one inlet and one outlet. Thanks in advance |
Re: boundary conditions
There's a relation ship between the flow rate and the pressure drop, so i think that in both way you should have the same results! the easiest way i think that's to use the pressure boundries for both inlet and outlet of the pipe.
Both are fine and should give you same results upon convergence. But fixed mass flow rate will normally converge faster.
