Home > Forums > CD-adapco
problem caused by the different materials
Old   November 21, 2005, 08:37
Default problem caused by the different materials
limingtiger
ctab,4,fluid,17,1,4,,,,,off,,light ctname,4, vc3d,0,10,10,0,10,10,0,1,2 $cset all $plty,ehid $cplo save,star.mdl geom,star.geom,1,binary,check,serial,
when I finished the commands listed above, the error as following: error #11 undifined material type assigned to cells. error #126 cell definition points to an undefined porosity model.
if i use the default materials there will be no any errors. what's the problem?
Old   November 21, 2005, 09:02
Default Re: problem caused by the different materials
Richard
If those commands completely define your model, then you have made two errors: your ctab command assigns cell type 4 to material number 4 and porosity index 1. Neither of these exist. Compare this the default fluid material, which has material number 1 (which exists) and porosity index 0 (which means none).
Thread Tools
Trackbacks are On
new materials in fluent by mixing other materials Anna FLUENT 0 January 18, 2009 05:53
Problems caused by fvcmeshPhi rolando OpenFOAM Bugs 26 April 3, 2007 10:34
Materials Problem john FLUENT 1 July 17, 2006 06:17
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
about erosion problem caused by solid particles hannah CFX 4 August 20, 2003 04:42
