November 21, 2005, 07:37 |
problem caused by the different materials
ctab,4,fluid,17,1,4,,,,,off,,light ctname,4, vc3d,0,10,10,0,10,10,0,1,2 $cset all $plty,ehid $cplo save,star.mdl geom,star.geom,1,binary,check,serial,
when I finished the commands listed above, the error as following: error #11 undifined material type assigned to cells. error #126 cell definition points to an undefined porosity model. if i use the default materials there will be no any errors. what's the problem? |
November 21, 2005, 08:02 |
Re: problem caused by the different materials
If those commands completely define your model, then you have made two errors: your ctab command assigns cell type 4 to material number 4 and porosity index 1. Neither of these exist. Compare this the default fluid material, which has material number 1 (which exists) and porosity index 0 (which means none).
new materials in fluent by mixing other materials | Anna | FLUENT | 0 | January 18, 2009 04:53 |
Problems caused by fvcmeshPhi | rolando | OpenFOAM Bugs | 26 | April 3, 2007 10:34 |
Materials Problem | john | FLUENT | 1 | July 17, 2006 06:17 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 10:57 |
about erosion problem caused by solid particles | hannah | CFX | 4 | August 20, 2003 04:42 |
