Home > Forums > CD-adapco
Cyclic Boundary
Old   November 28, 2005, 06:21
Default Cyclic Boundary
furkan
Hello
I have created 64*64*64 cells as a cube. I want to define cylic boundaries condition. First cyclic boundary should be -y and other one is +y side. So Both zx planes should be defined cylic boundary coundition. Is it possible to define this sitituon in norrow channels and if i do like this; is it correct or? Because this study has periodic flow conditions through y plane as a vertical.If it is not correct to use cyclic boundary condition for this issue, please tell me which command is correct.
Old   November 28, 2005, 10:12
Default Re: Cyclic Boundary
david vdl
hallo,
i think this command is correct. you can use cyclic boundaries to fix this problem. if you also use the cyclic boundaries in flow direction, be careful regarding the pressure drop between the two planes. you have to use partial boundary conditions.
david vdl
Thread Tools
Trackbacks are On
Cyclic Boundary Condition SG CD-adapco 0 June 1, 2008 14:56
Cyclic Boundary conditions johndeas OpenFOAM Running, Solving & CFD 1 January 4, 2008 21:34
cyclic boundary sijin james CD-adapco 3 May 15, 2007 12:07
Help!cyclic boundary Bard CD-adapco 0 December 16, 2006 07:41
Help on cyclic boundary!!! Mehdi CD-adapco 5 March 16, 2006 13:23
