Home > Forums > CD-adapco
=== Using multiple POSDAT.F - simple trick ===
Old   November 29, 2005, 06:09
Default === Using multiple POSDAT.F - simple trick ===
Murali
There may be instances when the simulation may require multiple versions of POSDAT.F to be used. For example, one POSDAT.F may be used to calcualte and another used to print. Everytime copy pasting the code or renaming the files as POSDAT.F may be a little boring / inefficient. In stead the following procedure can be adopted:
Suppose you have posdat1.f and posdat2.f for 2 different purposes. Rename them as POSDAT1.TXT and POSDAT2.TXT and keep them in the ufile folder. In the original 'empty' POSDAT.F generated by STAR, use the follwoing line:
INCLUDE 'POSDAT1.TXT'
if you need to run the first job. this command automatically transfers the control to the POSDAT1.TXT. Mind that though they are named .txt they still need to be in proper fortran format. else, this will result in compilation error. Also they cannot have the extension '.f' because star tries to compile them as separate files and ends up giving an error.
Old   November 29, 2005, 08:15
Default Re: === Using multiple POSDAT.F - simple trick ===
Mahesh Masurkar
Hi murali, this is good. Add this in wiki.
Old   November 29, 2005, 12:33
Ben
I may be wrong but I am fairly certain that using include files is a fair bit slower than directly compiled objects
Thread Tools
Trackbacks are On
CFL in posdat hamodi CD-adapco 2 August 6, 2007 02:27
=== Using multiple POSDAT.F - simple trick === Tommy CD-adapco 2 July 2, 2007 09:46
POSDAT Sheila CD-adapco 2 February 8, 2006 12:08
Mind Reader-What's the trick? Selina Tracy Main CFD Forum 5 April 24, 2003 12:18
posdat in HPC Won-Geun Lee CD-adapco 0 May 23, 2001 20:03
