vof & inlet
Old   November 27, 2005, 19:31
Default vof & inlet
azmir
Need some idea when simulating VOF whereby the heavy fluid is also imposed with an inlet velocity. Is this allowed? Or is there a few other settings which need alterations? I keep getting divergence after a few trials by adjusting the Courant number and time step and period.
Old   November 29, 2005, 11:36
Default Re: vof & inlet
Ben
if you want vof coming in through the inlet just turn the scalar conc at the inlet to 1.0 or do you want an initial field?
Old   November 30, 2005, 05:41
azmir
I'm more like experimenting. Thanks for the first tip. How about if I want to have an initial field for my 2nd case study?
Old   November 30, 2005, 05:57
Ben
Fiddle with your initialisation parameters
Old   November 30, 2005, 13:57
Anton Lyaskin
Initial field for VOF problems can be easily set with different cell types
Old   November 30, 2005, 19:37
azmir
That has been done, as shown in tutorial. Its limitation is that only gravity does the job pulling the heavy fluid cell type downward while free surface calculation determines the two fluids interaction..
In my case, in addition to gravity, I would like to impose a constant inlet velocity to this heavy fluid (something like impinging jet; only that the heavy fluid is heavy liquid and its flow rate is moderate high).
I can surely fiddle with parameter settings, and was hoping if lucky (taking advantage of this free forum) if someone would share more info so that I spend lesser time fiddling.
I am at the moment trying the first suggestion as we speak..
velocity inlet vs pressure inlet cheong FLUENT 6 April 9, 2011 03:07
subsonic inlet or supersonic inlet? mali CFX 0 November 28, 2008 20:57
about inlet bc ivanyao OpenFOAM Running, Solving & CFD 0 November 25, 2008 03:17
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
How to set smoke inlet speed on inlet Adam FLUENT 0 October 4, 2005 08:18
