Home > Forums > CD-adapco
not getting the required flow rate(kg/sec.)
Old   December 6, 2005, 04:20
Default not getting the required flow rate(kg/sec.)
nirmal
I am modelling a steady state case of flow through a tube (containing baffles) with one inlet and one outlet.At inlet and outlet, I have given pressure B.C.S. I am not getting the required flow rate(kg/sec.)Pressure drop corresponding to the flow rate have been calculated by empirical correlations and standard methods.Any way model is not giving any error on check. What may be the possible causes.???
Old   December 6, 2005, 06:06
Default Re: not getting the required flow rate(kg/sec.)
Richard
There could be modelling (especially turbulence) and discretization errors (coarse mesh) on the CFD side. But, on the other hand, be careful of putting too much trust in "empirical correlations" and "standard methods". Do you know for sure that these have the level of accuracy which you ascribe to them?
Old   December 8, 2005, 07:44
William Blake
Just go the other way. Define the mass flux and look for the pressure do you get.
Old   December 20, 2005, 04:28
Hubert Janocha
Does your empirical correleations take into consideration the possible bends / curvs, flow seperation, swirl, wall roughness, ... and many more physical effects?
Especially flow seperation is a problem, which is extremly affected by the turbulence model, and on the flow velocity (definition of RE-number).
Thread Tools
Trackbacks are On
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
* urgent help required for simulation of pipe flow mei Main CFD Forum 3 July 3, 2002 04:22
mas flow rate or mass flow rate? Giacomo FLUENT 2 February 5, 2002 05:41
component flow direction fieldnames for boundary profiles required. Ricky Wong FLUENT 1 May 12, 2000 10:36
