I can not find the pstt file
Old   November 7, 2005, 09:09
Default I can not find the pstt file
Z.H. Huang
hi,every one,I got a pstt file(3.2G),when I try to open it(window xp 32 bit),but the starcd pro-post can not show it,the file locate in E disk,I can visit it.why? too large?
Old   November 7, 2005, 17:15
Default Re: I can not find the pstt file
Tom
Many 32 bit systems will only let you open 2 gig files. You have divide it into two files by going to Tools>Convert>Star. Select the transient button and that lets you select the time steps. Use your input file, leaving it as binary and for your output file set the name you want with the pstt extension. Hit apply and watch STAR-CD do its magic. However, I would warn you to make a copy of your original file. Tom
Old   November 8, 2005, 02:03
Z.H. Huang
thank you,Tom! But the starcd can not display this file in the post module.Maybe the covert tool can not display it as well.
Old   November 8, 2005, 11:36
Tom
The convert tool does not display it. It allows you to break it up into two files so that you can look at the two files. Tom
Old   November 8, 2005, 18:48
Z.H. Huang
Tom: Maybe I did not express my idea clearly.sorry for that. I mean,there are several pstt files in some folder,but some of them are very small,maybe only 200M,the post module can recognize these pstt file,but the big pstt file(3.7G)will be negelect,post module DO NOT recognize this pstt file,just treat this as some other type file(not pstt file).
I worry the convert module can not recognize this file just as the post module.
I DO NOT mean,the convert modul will display the result of the simulation(the content in the pstt file).
Regard!
Old   December 6, 2005, 09:24
Hubert Janocha
Please see the question "How to manually merge a pst-file" on 21th Nov.05 5:35 a.m.
A few minutes ago I wrote a answer to this, which will help you, to avoid this problems in the future.
No .pstt file Luke Siemens 2 July 24, 2008 09:26
.pstt file Andy Siemens 6 March 28, 2006 02:07
Interrupted pstt file furkan Siemens 0 January 19, 2006 08:04
PSTT File Yuan Shen Siemens 6 November 7, 2000 08:09
