December 17, 2005, 12:04 |
Executabel size - Segmentation fault
Hi everyone,
my executable size is about 900MB and I cannot run it. Star gives me segmentation fault. Can someone tell me what can I do to be able to run cases of this size? I hope there is something that can be done. Please help. Sheila |
December 17, 2005, 13:19 |
Re: Executabel size - Segmentation fault
It woulg be wonderful if you tell us, which version of StarCD you are using on which platform.
If it is v315 you can do a "starlink -Y" |
December 19, 2005, 15:42 |
I am using version 3.15 on Linux. I tried the above suggestion (on a bigger file) and it did not work.
In case you ask, why am I still using an ancient version, I have to use v3.15 due to time shortage and some other constraints. Please help, thanks. Sheila |
December 19, 2005, 15:48 |
Here is what I have,
[rmb@metf1 dx_Nov10]$ starlink -snf star Message passing library: sequential Linking single precision sequential executable "star"... FORTRAN 77 Compiler 4.5, Copyright (c) 1987-1999, Absoft Corp. /opt/absoft/lib/libfio.a(lowlevel.o): In function `_temp_file': lowlevel.o(.text+0x10): the use of `tempnam' is dangerous, better use `mkstemp' Size of executable star = 906.848 MB [rmb@metf1 dx_Nov10]$ star Segmentation fault [rmb@metf1 dx_Nov10]$ starlink -help starlink [-sdgounfr2347BGipmhxPF] [-b mp_mbox] [-c casename] [-e executable] [-A MPI_ARCH] [-R MPI_ROOT] [-D MPI_DEVICE] [-S remoteSTARDIR] [-l libname] [-L libdir] [-U ufiledir -s link single precision executable -d link double precision executable -g compile user subroutines with debugging information -o optimise user subroutines -u compile user subroutines -n do not compile user subroutines -f overwrite executable if it already exists -2 Eulerian two phase version -3 Interpolation for carrier phase based on gra. -4 Interpolation for carrier phase based on vertex vel -7 Parallel AMG with special parameters -m use mpi -i use mpich -A specifies MPI_ARCH -R specifies MPI_ROOT -D selects MPI_DEVICE -S selects remote machine STARDIR -P link with patch libraries (obsolete) -l library "libname" to link in -L directory "libdir" to search for libraries -U extra ufile directory "ufiledir" -b Increase message passing buffer -c write batch script for "casename" -e write star executable named "executable" -t strip executable -x enable AMG algorithm (requires F90 compiler) -r Reynolds Stress Model -G link with GTPOWER -V link with V2F -F compile using freeware g77 (Irix only) -h print this message |
December 19, 2005, 17:07 |
starlink -help
starlink [-sdgounfr2347BGipmhxkPF] [-b mp_mbox] [-c casename] [-e executable] [- A MPI_ARCH] [-R MPI_ROOT] [-D MPI_DEVICE] [-S remoteSTARDIR] [-l libname] [-L li bdir] [-U ufiledir -s link single precision executable -d link double precision executable -g compile user subroutines with debugging information -o optimise user subroutines -u compile user subroutines -n do not compile user subroutines -f overwrite executable if it already exists -2 Eulerian two phase version -3 Interpolation for carrier phase based on gra. -4 Interpolation for carrier phase based on vertex vel -7 Parallel AMG with special parameters -m use mpi -i use mpich -A specifies MPI_ARCH -R specifies MPI_ROOT -D selects MPI_DEVICE -S selects remote machine STARDIR -P link with patch libraries (obsolete) -l library "libname" to link in -L directory "libdir" to search for libraries -U extra ufile directory "ufiledir" -b Increase message passing buffer -c write batch script for "casename" -e write star executable named "executable" -t strip executable -x enable AMG algorithm (requires F90 compiler) -k no save memory option for AMG algorithm -r Reynolds Stress Model -G link with GTPOWER -V link with V2F -F compile using freeware g77 (Irix only) -Y compile star executable with static system libraries (Linux only) -h print this message This is what I get from my version 315A. There you have to use "-Y compile star executable with static system". It should not be too hard to change from v315 to v315A. |
Display Modes | |
[Technical] Segmentation fault in map | msg30 | OpenFOAM Meshing & Mesh Conversion | 6 | March 27, 2008 11:49 |
Segmentation Fault | Kiran | Siemens | 3 | September 18, 2006 11:52 |
segmentation fault | tipakorn | Siemens | 6 | July 31, 2006 08:56 |
Segmentation Fault | Victor | Main CFD Forum | 5 | April 5, 2005 09:09 |
Segmentation fault | Veebs | Siemens | 3 | June 4, 2002 23:17 |
