December 23, 2005, 01:54 |
error
hello guys,
In <.info> file the error is shown(cell center outside of cell for cell no. 1 etc).But in check evrything no error is shown. Will it have any bad impact? Thanks in advance |
December 29, 2005, 00:52 |
Re: error
Hi, To me it seems that the mesh is not proper. Check all the cells for centroidal check using check tool option. Try to reduce the skewness of the grid by remeshing or by hand fixing. The exact impact on the solution for this grid cannot be predicted. Till the point you are getting converged solution, check the accuracy with benchmark. Try also increasing the convergence criteriorn. If your grid is good the decrease in convergence criteriorn should not change the solution significantly if the grid is good.
Display Modes | |
strange fluent error: Primitive Error at Node 0 | Jean-Baptiste | FLUENT | 8 | June 14, 2022 12:11 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
"Error: Floating point error: invalid number" | MI Kim | FLUENT | 2 | January 4, 2007 11:00 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 09:48 |
Error: Floating point error: invalid number | Bob | FLUENT | 3 | June 3, 2005 19:11 |
