URGENT HELP: Shells with PSCREATE CAVER Values |
January 12, 2006, 06:18 |
Hello, i have a deformable mesh, transient case ie. many pstt files. At the moment i do not have ENSIGHT and through STAR-CD forum hints i create shells at one plane S1 i am interested in, then average scalar quantity with CAVER and then use PMAP to map on S1. I then output on file star.plot then go back and do cset news shells S1 cdel cset ccom all vcom all ctdel all and continue for next time step. I do the ccom all and vcom all for using as little memory as possible. Is this procedure right? Am i getting the CAVER data for each time step correctly or somehow faking something, specially considering it is a deformable mesh? I am unsure therefore please help. Thank you starcd_learner
January 18, 2006, 23:14 |
Re: URGENT HELP: Shells with PSCREATE CAVER Values
It sounds right to me. I don't know why you need to delete and recreate the shells each time. You can either leave them or move the vertices with out having to delete everything but it doesn't hurt. You do realize that all CAVERAGE does is take cell centroid data and average it to the vertices to produce smoother plots? If you have moving grid data make sure you reconnect up to the event file so that the vertices/cells are moved in post-processing exactly like the solution run.
February 1, 2006, 11:03 |
thank you, in my particular case, through a fluid-structure-coupling i dont have any event file.
Display Modes | |
very urgent pleasade:Cl and Cd values for airfoil | Liaquat | FLUENT | 2 | April 27, 2006 13:20 |
projecting on shells | guest7777 | Siemens | 2 | April 4, 2006 09:45 |
my pro-am shells | Ted Crilly | Siemens | 3 | February 15, 2005 19:21 |
Shells | azmir | Siemens | 7 | August 17, 2004 01:33 |
filling of elastic shells | Nina Shokina | Main CFD Forum | 0 | December 11, 2001 02:54 |
